jbguitar44
First post here, but longtime RJM user (MMGT22, PBC/10, PBC/6X).
I’ve recently set up my MMGT22 to control the Axe-FX III, and it’s working great.
However, there’s something I’d like to do with block channel selection that I can’t seem to figure out.
In lieu of using an IA Cycle menu for channel selection, I’d like to treat the channels as individual effects, with interactive on/off control on each.
The Fractal FC-6/FC-12 has a function that does this called “Smart Bypass.” This is paraphrased from their manual:
When you turn Smart Bypass on, it allows Channel switches to engage or bypass an effect. Activating the Channel Select switch for an effect channel which is already active will BYPASS the effect. Activating the Channel Select switch for an effect channel which is already bypassed will ENGAGE the effect. This allows you to set up separate switches for different channels without the need for a separate “Bypass” Switch.
I’ve had success setting up a bypass switch and four channels across five switches. Over four switches, I’ve tried integrating the on/off command with channels via grouping, but I can’t get it to work (predictably, all turn on/off when pushing any switch). I’ve tried adjusting the global Button Group settings too.
Is this currently possible with the MMGT? Or am I doing something wrong?
BTW, I’m running the latest MMGT firmware (v4.5.0).
Thanks.
Jim
Thanks.
Jim
