OK, this is driving me nuts. First, I am using a Mac with 12.6. If I try to add a CC action for the Axe-Fx III or for the Collider in the Mastermind LT editor using the right click on the mouse, everything works fine. However, if I double click the button, set it to IA, and then try to use Add CC Action button in the IA Action section, for the most part nothing appears. Some of the actions work, but for the most part they don't.
The problem seems to be LT specific. I have three of them, two using Axe-Fx III with amps, the third using an Axe-Fx II XL+. With one of the LTs, the Add CC Action works fine. On the other, the problem exists. I tried a factory reset and uploading the setup, and it is still a problem.
In fact, if open the editor without to a new file without any LT connected and try adding CC actions with the button in the IA Action section, the same problem exists. I tried reinstalling the program. However, I just tried it on another computer, and the same thing happened. Just so I don't drive myself crazy, is this a bug? I can work for now using the right click mouse method, but it would be nice to have the Add CC Action work as well. Also, I can manually add the CC action in the IA Action section with no problem. However, to do that, I need to know what CC the LT is assigning to an Axe function.
As always, thanks for the help.
