overdrive59
My H&K Grandmeister amp has midi control. The amp has presets with digital effects that can be controlled by midi. I want to override the effect settings with the Mastermind and use the effects on my board. This is simple to do.
My question is, is there a way to automatically send a predetermined CC message for EVERY preset? For example, turn off the delay effect in the amp for each preset. Right now, the only solution is programming the identical CC message into every Mastermind preset. Yes, this is a trivial 21st century problem!
My goal here is to keep the amp presets intact. Most of the time I will override them with the Mastermind but in a pinch I might use the amp standalone with the internal effects.
