ReidarNikolai
Hi there
I am - suddenly - having some problems with a device using the GT.
I have an amp switcher that I use to switch amps on/off (head switcher) - with CC. The switches are grouped - no prob.
These are single channel amps.
Recently I added a channel switching amp.
I would like to use one button for changing the channel on the amp and put the amp switcher on to the right channel.
Two different CC´s - still grouped within the amp switcher.
It works when I go from channel 1 to channel 2 to channel 3 - but when I go back for example to channel 1. The preamp switches - but the amp switcher goes off. And I have to push the channel 1 button twice to get back to the amp "on".
I only assume this is possible - the CC on the amp switcher is on 0 (zero) for off state - on all 4 channels. The group allows all off.
If I switch between the amps - it is working like it used to - but when I start changing the channels on the one amp - the amp switcher gets turned off (on that amp)
The channel switcher is an axess CFX-4 BTW.
Any advice?
I think I have tried all
Thanks in advance
Reidar
Any advice?
Thanks in advance
Reidar
