Default Scene State Axe-Fx III
Discussion in 'GT General Discussion' started by Dwelltone, May 28, 2020.
  1. Dwelltone
    Dwelltone
    May 25, 2019
    17
    2
    This may have been a change in 4.4.3, I no longer see Scene 1 as active on my GT22 when changing presets in my Axe-Fx III. It seems like all the other states update but not the Scene button. I may have missed a setting that needs to be updated to make that work again.
  2. Dwelltone
    Dwelltone
    May 25, 2019
    17
    2
    Bueller? :)
    Am I the only one having this issue?
  3. rjmmusic
    Staff Member
    Jan 18, 2010
    6,442
    1,166
    Is Update on Preset Change turned off on your scene buttons? (It should be off in order for the Axe-Fx to control them)
  4. Dwelltone
    Dwelltone
    May 25, 2019
    17
    2
    Yes, it is off on all my scene buttons. The only thing that is checked is "IA Link" on all my scene buttons. When I went to confirm my settings the scene 1 button was on after initially turning on the unit then when I changed presets it was off on the next preset and stayed off when going back to the preset that it was on when powering up. I edited my scene 1 button by reselecting the Assign CC>Axe Fx III>Scene 1 and sent the change to the GT22. It was on after pushing to the device but then repeated the same behavior as above. I am using the local page 16 with per preset configs. It seems like with an initial power on or config push it works/updates but then once I change presets it's not updating. I'm using the 4.5.0 editor and 4.5.0 fw. It seems that it is only the scene button that doesn't update state when changing presets.
Share This Page
