I am setting up a custom page to scroll presets on 6 midi devices and have show button names enabled. Timeline, Mobius, BigSky, H9, Reflex Expression and Infinity Looper are the devices, all are setup the same with the device and led color as the only changes. On the H9 and Reflex the Device PC-/+ buttons work great. On the 3 Strymon pedals, the buttons are not acting as expected.
On the timeline, it shows 1/1 when pressing device pc+ for ten presets then 1/2 for the next ten and so on, on device pc- it just shows 1 or 0 continually. Also it doesnt appear to stop at the end of the presets for each pedal, meaning when I advance to the end of the preset list the pedal stops changing and stays on the last preset, the pbc keeps going though and if I overshoot the last preset by a few button presses, I then have to press device pc- a few presses til it reduces the pc number down.
This is the same for the other two strymon pedals.
On the infinity looper, when selecting the device and then using the hold function of two of the buttons to change the presets, the pedal doesn't seem to respond but the pbc says its increased/decreased the preset. Midi channel is correct on device and pbc for the looper.
Is there a way to do the following:
1. Define for the pcb the number of presets per device, this comes in handy not just for strymon but all midi devices moving forward.
2. When the pbc reaches the end of the number of pc changes for presets, it either stops and displays a message or scrolls back around to number 1. For instance 200 presets would scroll to preset 1 at 201.
3. Update the display correctly to show which bank and pc number is being sent? Currently Im lost on the strymon pedals regarding where I am.
4. Add a bypass and Dont care pc/cc to the scrolling list so that we can save that for the state of each pedal. This way you can bypass it on a preset but still have the same preset setting, or don't care would allow you to come from another preset into that device would do what it was doing before the pbc switched presets. This is similar to how my old Disaster Area DPC-8d worked.
5. How do I configure the infinity looper device to react to pc-/+ buttons so that I can recall a preset.
On a side note, if I set it up this way, my hope is that I can select the configuration from each pedal from one page and then if desired, save the state of each pedal to a preset using the IA save function that I still have setup in the corner as a hold function of the loops button. Thanks!
