fusionpete
Looking for some advice.
I have both the PBC 10 and 6x on different boards (currently building).
On the 10, I have a Strymon Iridium and on the 6x, a Strymon Volante and Jet Revelation.
All these pedals save their presets on receiving a midi pc change defining the program number where you want to assign each preset. The Strymons also have presets split into 3 banks as these exceed the normal midi numbering, so that means a Bank Select cc message has to be used when using banks 1 & 2. 0 is the default and I doubt I will reach 127 presets, but it would be handy to have this also catered for.
As I will be making presets, I’m looking for advice as to the best / easiest way to do this and then to save via the PBC.
I was thinking I might need separate button pages per pedal with a midi message to enable the pedal, but how can I deal with saving the preset and sending an appropriate midi pc number each time. I think I can assign a button to load, but this means manually changing the pc number each time. I hope there is an easier way & I’m sure others here have done this, so I’d appreciate any advice.
Thanks
Thanks
