If you want two independent signal paths, then it'll need to be something like this:O.K.
Tuus far I have according to your suggestion :
Loop A = loop1
Loop B = loop 6
Out 1-5 goes tofront of amp
Amp send to return 1-5
Output A to amp return
That allows me to split the HX as wanted but I would like to setup a wet/dry system while splitting the HX and sending only a clean signal to the wet amp
I am lost
If you can help. Anyone ?
nothing in the HX return ? not getting any signal to wet amp...If you want two independent signal paths, then it'll need to be something like this:
Loop 1 send to HX Return (this splits the clean signal to go to the wet side)
Loop A send to HX input
Loop A return to HX send
Output 1-4 or Output 7-10 to dry amp input
HX output to In 5-6 or In 7-10
Output A to wet amp input
Turning on loop 1 enables the wet amp.
