Flow
Hi
Im a french user. I'm sorry if I write not correctly. I will do my best !
In first I've read this post: http://www.rjmmusic.com/2016/03/29/using-stereo-pedals-with-the-mastermind-pbc/
My PCB Firmware is 3.1.5, my editor Firmware is 3.1.4.
Audio configuration:
- loop7 and 8 are locked in serie
- loop9 and 10 are locked in parallel with trails
- All buffers are On
- Input 1, Dry Mix, OutputA, OutputB are On
External buttons:
- "Mono->Stereo (out)" : button not pressed
- "Mono Output" : button not pressed
- "Iso B" : button not pressed
My signal chain:
- Guitare -> Tuner -> Input 1 RJM PCB
- Loop1 to 6 (comp / drive / boost) with a Selah Scarlett3 betwen "Out1-4" / "In 5-6" controlled by midi
- "Out5-6" -> ISP Decimator -> Volume -> "In7-10"
- Loop7 : Nano Pog (Ring disconnect cable for PCB -> Nano Pog Input; Mono/Stereo converter cable for Nano Pog output -> PCB)
- Loop8 : Walrus Julia (Ring disconnect cable for PCB -> Nano Pog Input; Mono/Stereo converter cable for Nano Pog output -> PCB)
- Loop9 : Strymon Timeline (stereo with Y cable)
- Loop10 : Eventide H9 (stereo with Y cable)
- OutputA + B -> Strymon Bigsky (stereo with two mono cable) -> Two amps
The issue:
I have the left side outcoming from Output A, but a windy silence from Output B.
If I bypass loops7, 8, 9 and 10 : same result.
If I press the button "Mono output" I can hear my guitar in Amp 1 and Amp 2... but I've only the half of the stereo image.
I love my RJM PCB, it's a fantastic switcher. But I really don't know what should I do now...
Please help me
External buttons:
My signal chain:
The issue:
Please help me
