Issues with Source Audio Collider
Discussion in 'PBC General Discussion' started by PianoMan, Jan 13, 2020.
  1. PianoMan
    PianoMan
    Apr 20, 2017
    111
    21
    I'm having some issues getting my Source Audio Collider up and running with my board. Almost everything is good to go, except for toggling the bypass state of the A and B sides of the Collider. I have a page on my PBC to control their states, with a button devoted to the bypass state of each pedal that I can control on a per-preset basis. No matter what I do though, when I switch presets, it always defaults to having the A side on, and the B side off. I know the toggles work (if I tap them manually, the Collider follows them when they sync up), and I've verified that the MIDI messages are being sent on preset changes via MIDI OX. Anyone have any ideas what might be causing this?
  2. rjmmusic
    Staff Member
    Jan 18, 2010
    6,136
    1,102
    You have two buttons on page 3 that send Bypass messages to the pedal. I don't know what the difference is between the two ("Bypass" and "Recall Bypass"), but the problem might be related to both of them being sent when you change presets.
  3. PianoMan
    PianoMan
    Apr 20, 2017
    111
    21
    That's a remnant of me using the SA Ventris as a starter device when setting everything up. On the Collider, those CC messages control the bypass state of each of the two separate sides of the pedal.
  4. rjmmusic
    Staff Member
    Jan 18, 2010
    6,136
    1,102
    I have no experience with that pedal, some experimentation is going to be needed. I recommend removing some MIDI messages and see what happens. For example, turning off Send PC in Devices would prevent the PBC from sending PCs to the pedal. It would be helpful to see if this is one of those pedals that doesn't respond to MIDI messages for a while after a PC is received.
  5. PianoMan
    PianoMan
    Apr 20, 2017
    111
    21
    I've been in touch with Source Audio support and it turns out the issue is that the Collider can't handle multiple PC/CC messages at a time - it requires a delay in between each. Is there a way to add a delay between specific messages?
  6. rjmmusic
    Staff Member
    Jan 18, 2010
    6,136
    1,102
    Not at this time, sorry... It's been requested a few times, but it's not a simple feature to implement (if' it's done well)
  7. PianoMan
    PianoMan
    Apr 20, 2017
    111
    21
    Darn. Thanks for the help anyways!
  8. keg8605
    keg8605
    Apr 25, 2018
    20
    1
    Hey Pianoman- I have been starting to work in a collider to my pbc setup. Have you found some work arounds or tricks to controlling the collider?
  9. PianoMan
    PianoMan
    Apr 20, 2017
    111
    21
    Unfortunately I confirmed with Source Audio that what I was wanting to do is not possible. I ended up creating multiple iterations of each preset with the desired time signature. Annoying, but so be it.
    keg8605 likes this.
  10. keg8605
    keg8605
    Apr 25, 2018
    20
    1
    Gotcha, I played around a good bit tonight and seems this is probably the only option until delayed midi gets implemented. There are a number of pedals that need that. Would be nice to bring this into the midi options.
  11. Jhansenku
    Jhansenku
    Feb 15, 2020
    14
    0
    So are you going to be able to use the collider in your setup? I’m asking because I have the PBC 6x on order but haven’t ordered my collider yet. But that’s the pedal I was wanting to get. Is there easier options? I just don’t want to get over my head.
  12. PianoMan
    PianoMan
    Apr 20, 2017
    111
    21
    I'm using it now and have no intention to get rid of it. I just have to use more presets than I hoped I would have to. I still think it's the best option for dual delays out there.
  13. keg8605
    keg8605
    Apr 25, 2018
    20
    1
    Hey guys, just to update. I stumbled on what I think works by using a different controller (morningstar mc6). But I believe this solution should work with RJM. (Not sure if it does what you need PianoMan)
    Anyways, by using the CC commands 105 to 108. You select the correct cc, then the value of 0-127 is actually the preset you want. So if you want delay active and reverb off with your pc 4. You send cc 106, value of 4. I was missing this earlier.
Share This Page
