wire_twerp
I cannot explain unusual behaviour with this device. I'm using it in conjunction with a Fractal FM3 and the connections (all new, handmade pro cables) are routed via a Kenton 5 way splitter.
The FM3 is device 1 and the Lexicon is device 2; they are allocated to corresponding MIDI channels. I have set up the device TABS as recommended on the forum. My problem is that when I change FM3 presets using the PBC (or change scenes when in Song mode), the presets are also changed on the Lexicon!
I have the correct settings on the Lexicon on the MIDI control page, the receive channel is set to 2. I am using it in parallel with an RME UCX for audio but this should have no impact as they are not MIDI connected.
There are no Lexicon PC commands set up on my Presets tab on the Mastermind Editor so I would have expected that no PC commands should be sent to the Lexicon - yet they clearly are. However I set up the Lexicon device page I get the same behaviour. This is a real problem because the Lexicon takes almost two seconds to change presets. Although the signal is not muted I just get dry signal and it would not work in gigs.
I am almost at the point of ditching the Lexicon as I cannot work with it in at the moment and it would be a disaster live. The PBC works fine with the FM3 and my pedals and amp.
I would value any help, explanation, insight or potential workarounds.
