Joel Walker
Hi Ron --
I'm using a Mission SP1-RJM expression pedal with my GT/16.
The switch output (jack 2) on the pedal is connected with a TRS cable to the External Switches 1/2 input on the back of the GT.
In the Editor on the buttons page the "Ext switch 1" is configured as a Normal IA button.
The red light on the expression pedal is always on. It goes off momentarily when the pedal toe-switch is engaged, but comes back on when it is released. (The actions triggered by the switch do seem to work correctly.)
My understanding of the expected behavior is that the LED on the expression pedal should toggle on/off every time the toe-switch is pressed, as the IA switches between on/off status.
Firmware and editor versions are current (4.3.0).
Can you help?
Joel
Can you help?
Joel
