Firmware 3.3.1 is now available. This one adds some new features and a couple of new devices
UPDATE 8/29/16 - Version 3.3.1
This update adds the following changes:
1). BACK UP YOUR SETTINGS!!! If you have to go back to 3.2, your GT will factory reset.
Note: the first time the GT boots up after the update, it will need to convert your settings to 3.3 format. It will take a few minutes to do this, so be patient and let it finish!
Here are the files:
Firmware: http://www.rjmmusic.com/downloads/MMGT331.zip
Manual: http://www.rjmmusic.com/manuals/Masterm ... al-3.3.pdf
Mac Editor: http://www.rjmmusic.com/software/MMGTEditor-3.3.0.dmg
PC Editor: http://www.rjmmusic.com/software/MMGTEditor-3.3.0.zip
An online manual for the editor can be found here: http://www.rjmmusic.com/wiki/
The PDF version is here: http://www.rjmmusic.com/manuals/Mastermind Editor Manual.pdf
- Added support for Chase Bliss pedals and Mesa JP2C
- Added Auto Tap - this allows the GT to automatically send tempo taps as MIDI messages to pedals that support them. Each time the tempo changes due to a preset change, new taps will be sent. The number of taps can be configured, as can the messages that are sent.
- System Page and Preset actions now have special values available - "Up", "Down", "Previous" and (in the case of Preset) "Global". These allow you to switch up one preset or page, down one preset or page, switch to the previously selected preset or page, or switch to the global preset.
- Groups can now have their own actions. This only works when "Allow All Buttons Off" is turned on for a group. The actions are run when you switch from having no buttons on in the group to having one button on, and vice-versa. An example of using this is to have a group of buttons selecting presets on a pedal. When any of the preset buttons are on, you can use the group actions to enable the pedal. When all of the preset buttons are off, the group action can bypass the pedal.
- Hold functions can now have their own colors. You can specify colors for all combinations of normal function on/off and hold function on/off states.
- "Direct Send" setting for devices switches off all of the duplicate message filtering and other tricks the GT does to try to reduce the amount of MIDI messages sent. One side effect of that filtering is that CC messages will not necessarily be sent in the order you specify in the action list. Turning on Direct Send disables all message filtering, and messages will be sent in the order specified.
- New settings for "Preset 2nd Press" option: "Same" means that pressing a preset button a second time keeps you on the same preset and does nothing. "Reload" means that pressing a preset button a second time will keep you on the same preset, but will reload the preset, resetting the state of IA buttons and device PCs to whatever was stored in the preset.
- Added support for real-time looper status messages from the Axe-Fx II and newer models. This updates the looper play, record once, etc. buttons to accurately reflect what's going on in the Axe's looper.
- You can now choose a macro to run when the GT starts.
- Added a setting to display or not display tempo in the main display when the tempo changes.
- Removed "Off" value settings when editing Preset Actions - they didn't have any effect anyway.
- Various bug fixes
- Fixes the case where a button's normal function is disabled, and the hold function is enabled. You can now access the hold function.
- Fixes issues with 0.0 tempos being displayed in tempo buttons.
- Fixes an issue that prevented preset buttons from displaying the correct presets when Init Last Preset is turned on.
- You can now specify a preset or song tempo of "0.1" to tell the GT to keep the same tempo when switching to that song or preset. This will be given a more user-friendly special value name "Same" in the next major release, but I didn't want to hold up this feature waiting for an editor update.
Here are the files:
