MASTERMIND GT FIRMWARE 4.4.1 /EDITOR 4.4.0
Discussion in 'GT General Discussion' started by rjmmusic, Nov 13, 2019.
  1. rjmmusic
    Staff Member
    Jan 18, 2010
    5,970
    1,076
    Here's a new beta release for you, with some bug fixes and user requested features. Please test it out if you have the time!
    FEATURES:
    • Added "Update Preset Name" button type - pressing this updates the current preset name (and scene names, if applicable) from the connected device (typically Axe-Fx)
    • Support for GFI System pedals: Cabzeus and Specular Tempus. Also support for Strymon Iridium and Chase Bliss Mood
    • Added ability to update device firmware from editor. Only works with devices that have 2.0 bootloader (built June 2019 or later)
    • Tapped in tempos are now preserved when switching presets within a song, if preset tempos are set to Song, or if "Ignore Preset Tempos" is turned on.
    • Added two special values to the ExpPedal action: "Same" does nothing, and "Send" sends the expression pedal's current value again
    • "Decimal Tempo" setting controls whether tempos are displayed with one decimal place or as whole numbers only
    • Added setting to reverse Bank MSB and Bank LSB CCs for incoming bank selection
    • Added sysex message to be able to post a message on the main screen
    • Doing Assign CC of an Axe-Fx III effect block in the editor now automatically adds the "hold to select channel" functionality, like it does on the GT itself. This works when right-clicking on a button in the Buttons tab and selecting "Assign CC" or "Assign Default Buttons".
    BUG FIXES:
    • Turning on "Update on Preset Change" on a button will now disable state updates from an Axe-Fx III, like it does on previous models
    • Fixed screen formatting issues in calibrate menu and channel select menu
    • Fixed bug that kept Get Preset Names running after it was cancelled
    • Kemper tuner and tempo now work even if Ignore Incoming CC is turned on
    • Fixed state update of Kemper Reverb button
    • Fixed a bug that prevented long Sysex messages from being sent over USB. (This happened when using more than one Sysex action to build a longer message)
    • Fixed a bug with "Send Off Msgs" group setting
    • Fixed a screen bug that caused scene name to flash
    • Fixed editing of special values in the GT setup menu
    • Fixed Axe-Fx tuner that was off by 1 cent
    FIXES FROM BETA RELEASES:
    • Fixed occasional crashes in Update Preset Name
    • Update Preset Name no longer changes the stored page number in the preset
    • Fixed data corruption on button page 10
    • Fixed missing scene name display when using Preset -/+ buttons
    • Fixed warnings when running editor in MacOS Catalina
    FIXES IN 4.4.1:
    • Fixed a bug that caused problems if you had normal IA and IA cycle buttons with the same IA ID.
    • Fixed a bug that caused Poll State to interfere with Update Preset Name
    TO UPDATE FIRMWARE:
    - First, back up your settings to a flash drive or computer! If you go back to 4.2 or earlier, your GT will factory reset.
    Firmware: http://www.rjmmusic.com/downloads/MMGT/MMGT441.zip
    Mac Editor: http://www.rjmmusic.com/downloads/MMGT/MMGTEditor-4.4.0.dmg
    PC Editor: http://www.rjmmusic.com/downloads/MMGT/MMGTEditor-4.4.0.zip
    Manual: http://www.rjmmusic.com/downloads/MMGT/Mastermind GT Manual-4.3.pdf (update coming soon)
    Editor Manual (not updated for 4.4 yet): http://www.rjmmusic.com/wiki
    #1 rjmmusic, Nov 13, 2019
    ANASON Records, AdrianG and Alexander like this.
  2. Alexander
    Alexander
    Oct 21, 2014
    455
    157
    Wonderful, will install tomorrow.
  3. rjmmusic
    Staff Member
    Jan 18, 2010
    5,970
    1,076
    Well, I found a bug already... The Update Preset Name button type is not available in the editor, you can only select it when editing on the GT itself. Make sure that, once you select the Update Preset Names button type, you also specify which device the button affects.
    iaresee, Alexander and AdrianG like this.
  4. AdrianG
    AdrianG
    Oct 15, 2018
    72
    15
    This is super!! Thank you Ron!!
  5. iaresee
    iaresee
    Sep 29, 2018
    98
    58
    Very excited for the update preset name button! Thank you!
  6. Alexander
    Alexander
    Oct 21, 2014
    455
    157
    Installing the firmware (using hardware setup) freezes on the logo screen.
    First the message "preparing memory" appears, then the progress bar runs, then the logo screen appears (4.4beta1) and freezes.
    No problem, restoring 4.3 worked.
  7. rjmmusic
    Staff Member
    Jan 18, 2010
    5,970
    1,076
    I'm not seeing that here, can you send me your settings?
  8. Alexander
    Alexander
    Oct 21, 2014
    455
    157
    Attached.
  9. rjmmusic
    Staff Member
    Jan 18, 2010
    5,970
    1,076
    Firmware 4.4beta2 is now available, which fixes the lockup issue. There will be a beta 2 of the editor later today.
  10. Alexander
    Alexander
    Oct 21, 2014
    455
    157
    Nice and fast. Installed successfully.
    #10 Alexander, Nov 14, 2019
  11. rjmmusic
    Staff Member
    Jan 18, 2010
    5,970
    1,076
    Editor beta 2 is now available. It fixes the missing "Update Preset Name" button type. I also decided to sneak in support for the Chase Bliss Mood
    Jop and AdrianG like this.
  12. AdrianG
    AdrianG
    Oct 15, 2018
    72
    15
    Hi Ron, I have loaded 4.4beta2 and I found 2 things:
    1) The Update Preset Name works for the Preset Name, but it doesn't update the Scene Name. Is it possible to do this as well please?
    2) When I pressed my button that runs Update Preset Name, my GT22 stopped displaying the Scene Name on my Main screen. I have tried to get this back by ticking/unticking the Show Scene Names but this doesn't work.
    I have attached my system file for you in case you want it.
    EDIT: The Update Preset Name button is on Page 2, top row.
    Many thanks,
    Adrian.
    #12 AdrianG, Nov 15, 2019
  13. rjmmusic
    Staff Member
    Jan 18, 2010
    5,970
    1,076
    Update Preset Name takes its settings from Get Preset Names - make sure that Get Scenes (and Create Songs, if you're using songs) is turned on in the Get Preset Names screen.
  14. AdrianG
    AdrianG
    Oct 15, 2018
    72
    15
    Ah ok cool, thanks! I will try that now!
  15. AdrianG
    AdrianG
    Oct 15, 2018
    72
    15
    Thanks Ron, that works beautifully! Those settings must have reset when I updated.
  16. AdrianG
    AdrianG
    Oct 15, 2018
    72
    15
    Ok, having played with it some more I have found it sometimes hangs on my GT. The main display is slightly different for each time it hangs, I had rebooted the GT between the screenshots. I basically push the button (Update Preset Names on page 2) and it works the first time, then hangs when you push it again. The only way out is to disconnect the USB and reboot the GT.
    Oddly I still cannot get Scene Names to show on the main display, but the Update Preset Name updates the Scene names in my lower row perfectly.
    FWIW - Axe-Edit is not running at the same time either which might cause interference
    #16 AdrianG, Nov 15, 2019
  17. AdrianG
    AdrianG
    Oct 15, 2018
    72
    15
    Hmmm, the built in Get Preset Names appears to be hanging as well. I will go back to 4.3 and check that still works there to see if the issue is on my Axe-FX.
  18. AdrianG
    AdrianG
    Oct 15, 2018
    72
    15
    4.3 works fine, it gets the preset names as expected.
  19. rjmmusic
    Staff Member
    Jan 18, 2010
    5,970
    1,076
    Please let me know - are you using Create Songs as well as Get Scenes?
  20. AdrianG
    AdrianG
    Oct 15, 2018
    72
    15
    No problem, I'm just using Get Scenes.
    EDIT: I don't use Song mode
Share This Page
