MASTERMIND PBC FIRMWARE / EDITOR 4.5.0
Discussion in 'PBC General Discussion' started by rjmmusic, Jun 18, 2020.
  1. rjmmusic
    Staff Member
    Jan 18, 2010
    6,442
    1,166
    Another new release for you...
    FEATURES:
    • (UNTESTED) Support for Fractal Audio FM3 and Strymon Compadre
    • Dev PC -/+ and IA buttons that select presets on devices can now be linked together so that selecting one updates the other. Any time a PC or bank message is sent to a device, the Dev PC buttons will update to reflect the new numbers. If an IA button has a CC0 or CC32 action followed by a PC action as the first two messages, or just a PC action as the first action, and IA Link is turned on, the IA button respond to other IA buttons and the Dev PC -/+ buttons. For example, a button that sends PC 10 to a device will automatically turn on when PC 10 is sent to the device, even if it was sent by another button.
    • The MIDI Merge setting has been broken into In, Out and USB settings. You can use these to choose which ports are forwarded to the output, and which aren't. If you were merging from the In to the Out port, you will have to manually turn on the Merge: In setting after upgrading to this release. The Out setting is new and allows the input side of the bidirectional MIDI Out port to be forwarded out the MIDI Out port, which wasn't possible before.
    BUG FIXES:
    • Fixed drag-to-swap feature - it didn't work correctly when dragging to external switches
    • Fixed some CC values for Strymon pedals
    • Fixed special characters in preset, song and setlist names
    TO UPDATE FIRMWARE:
    - First, back up your settings to a flash drive or computer! If you go back to 4.2 or earlier, your Mastermind will factory reset.
    -OR-
    - Use the Transfer / Update Firmware menu option to update the Mastermind. This works with the PBC/6X and PBC/10s made after March 2019.
    Firmware: http://www.rjmmusic.com/downloads/PBC/MM450.zip
    Mac Editor: http://www.rjmmusic.com/downloads/PBC/MastermindEditor-4.5.0.dmg
    PC Editor: http://www.rjmmusic.com/downloads/PBC/MastermindEditor-4.5.0.zip
    PBC/6X Manual: http://www.rjmmusic.com/downloads/PBC6X/PBC6X Manual-4.3.pdf
    PBC/10 Manual: http://www.rjmmusic.com/downloads/PBC/PBC Manual-4.2.pdf
    Editor Manual: http://www.rjmmusic.com/wiki (not yet updated for 4.5)
    #1 rjmmusic, Jun 18, 2020
  2. P-air
    P-air
    May 10, 2019
    35
    1
    Hi
    I try to update the firmware of my PBC to 4.5
    I follow the procedure but when i get to the Bootloader i insert the flash drive i get the message unable to open directly.
    My PBC is 4.3.0 and i tried updating to 4.3.2 and i get the same message.
    #2 P-air, Jun 21, 2020
  3. rjmmusic
    Staff Member
    Jan 18, 2010
    6,442
    1,166
    A few things to try:
    - Make sure you're selecting "Eject Drive" on the computer before removing it
    - Make sure the file is not zipped - if it is, double click the zip file to extract the rjf file inside, and copy that to the drive
    - Delete all rjf files from the flash drive except the one you want the Mastermind to load
    - If none of that helps, try a different flash drive. USB 3 drives have problems with the Mastermind, and larger flash drives can be problematic as well 32GB or less USB 2.0 flash drives tend to work the best.
  4. P-air
    P-air
    May 10, 2019
    35
    1
    I do eject drive
    The file i get when clicking on the firmware download link is not Zipped, it is named MM450.rjf and is 543K big. If i clic on it it opens the editor.
    All rtf files are deleted from flash drive.
    Flash drive used is the one i got from RJM when i bout the type Mastermind spring 2019.
    I have used it to update to 4.3.
    And i still get the unable to open directly when i get to bootloader (2.0)
  5. rjmmusic
    Staff Member
    Jan 18, 2010
    6,442
    1,166
    I tried downloading the file and I was able to update a PBC using it. If you have bootloader 2.0, try updating using the Firmware Update option in the Mastermind Editor's Transfer menu - you can do the update over the USB connection to the computer instead of a flash drive.
  6. P-air
    P-air
    May 10, 2019
    35
    1
    Hi. Just did the Firmware update option. Worked great.
    Thanks for answering all my questions.
    Best regards.
    Pierre
  7. Jhansenku
    Jhansenku
    Feb 15, 2020
    38
    0
    Trying to update to 4.5.0. I'm using the transfer/update. I get an error saying: error validating: file block to long. Not sure what to do from there? Also, should you update both firmware and editor? Any order on doing so better?
  8. rjmmusic
    Staff Member
    Jan 18, 2010
    6,442
    1,166
    Update the firmware first, although it doesn't really matter. I recommend downloading the firmware again, maybe the last download got corrupted.
Share This Page
