I'm using the Mastermind PBC with two Chase Bliss pedals, the Blooper and the Mood. MIDI control of these pedals with the PBC generally works great. But there's one thing I've noticed that's a constant frustration. When I switch from one preset to another, it always sends a MIDI signal to the Chase Bliss pedals, causing them to stop whatever it is they were doing on the prior preset. This is the case even if I have them checked off in the editor app, so that no MIDI signal should be being sent to them.
Have others noticed this? Is there a way to fix this problem? For example, I'd like to be able to run a loop in the Blooper via one preset, and then switch to a different preset with the loop continuing to play, instead of automatically being turned off (which is what happens whenever I switch presets because the Blooper is sent a MIDI signal regardless).
