Hi. I recently got a mini gizmo handed to me so I bought the JSX interface cable right from RJM. I'm having a bit of trouble as I'm getting non-consistant channel changes.
I have a Boss GT-8 hooked up in 4 cable method so the effects loop must be on at all times. I have the interface cable with yellow end going into the "amp" of the gizmo and the JSX end going into the footswitch jack on the head. I have my 5 pin MIDI cable running from the OUT of the GT to the MIDI IN on the gizmo. I also have my channel on the JSX set to ULTRA because that was required for the footswitch (not sure if that matters now, but it is)
So here's what I'd like to get going and the wet patches are already set, just need the channels to line up.
bank 20-1 clean channel 1, delay, chorus
bank 20-2 dirty dry channel 2
bank 20-3 channel 3 ultra with delay
bank 20-4 channel 2 with other effects
So I follow the instructions that came with the cable holding switch 8 when plugging in until everything flashes then stays on, then press switch 3. SO then the amp in on channel1 clean with the LED on gizmo on 1 and the write is green. I wanted the FX loop on to I pressed switch 5 and wrote it, it flahed a few times and so #1 and #5 is ON.
So now I want 20-2 so go there on teh GT, then I switch to LED 2 and also LED 5...write them, got the flashes.
Same for 20-3, went on the GT to 20-3, pressed in #3 and #5 so they both lit up and wrote them both....flashed looks good.
Now here's teh problem, when I kinda randomly switch between those 3 patches, of 20 times, maybe 3 times would go to the correct channel and work perfect. The other 17 times, it would be a mix of other random channels although the LEDs looks correct as I programmed them. Somtimes I can go from 20-2 to 20-3 and it will be ultra fine, but then i got back to 20-2 and its channels 2 fine, but go back to 20-3 again and its now channel 1 and nothing has happened exect me just switching my GT patch.
Can I get some help to get thru this thnx. BTW I did watch a few videos on the net and it sure seems easy, but not the results that I expected....yes I also have the manual and have looked at it but its over my head. I have another dozen banks to program as well.
