I just got a Rack Gizmo and noticed that the main display on the GT now shows a "?" instead of the tuner status. Here's the skinny:
Previous setup (that worked):
Mm-GT powered by its AC adapter
Connected to AxeFx-II via 5-pin MIDI cable
New setup (that doesn't work):
MM GT connected to Rack Gizmo via 6-pin XLR MIDI cable
Rack Gizmo is powered using the MM GT AC adapter instead of the RG's AC adapter (per Ron)
Rack Gizmo is connected to AxeFx-II via 5-pin MIDI cable
Nothing else is connected to the Rack Gizmo
Preset selection works fine from the GT (only), but when I select the tuner button on the GT the tuner on the AxeFx-II activates like before but the main display on the GT shows a question mark "?" instead of the tuner status (see image). I also noticed that when I change presets via the AxeFx-II it doesn't change on the GT, so I seem to have lost my bidirectional functionality (probably the cause of the missing tuner).
I've tried with both firmware 1.0 and 1.1 on the GT. I also initialized the Rack Gizmo per the instructions for using my Mesa MkV interface cable.
Ideas?
Ideas?
