Version 2.3.1 is a minor update that improves syncing with Axe-Fx and Kemper KPA. We've greatly improved scene control on the Axe-Fx, and fixed things with the Kemper to work with Kemper 3.0 firmware. It now synchronizes much better with Performance mode.
Also, we've added a "Sync Names" parameter to Axe-Fx and Kemper devices. When this is turned on, it will automatically update the preset names in the GT with preset names in the Axe-Fx or Kemper. This happens as the presets are selected on the GT.
Some specifics for each device:
Axe-Fx:
The Axe-Fx only sends preset names for the currently selected preset, so the names will only update when you select each preset on the GT. So, when you start the GT up after installing this update (and turning on Sync Names), preset 1's name will update to match what's on the Axe-Fx. The other presets will not update their names until you select preset 2, preset 3, etc.
Kemper (Browse Mode):
The Kemper Browse Mode support works exactly like the Axe-Fx above.
Kemper (Performance Mode):
Performance mode updates one performance (aka bank) at a time. As you press bank up and bank down, the five presets in each performance will have their names updated.
Once you've enabled this and downloaded your preset names, you probably should read your settings into the editor to preserve those newly downloaded preset names.
UPDATE 4/8/2015 - Fixed some bugs in the editor that affected IA buttons, especially those that are grouped.
DOWNLOADS:
Firmware: http://www.rjmmusic.com/downloads/MMGT231.zip
Mac Editor: http://www.rjmmusic.com/software/MMGTEditor-2.3.2.dmg
PC Editor: http://www.rjmmusic.com/software/MMGTEditor-2.3.2.zip
Axe-Fx:
DOWNLOADS:
