Hi
@rjmmusic,
I have a PBC6 and recently got an HX stomp and want to wire it in such a way that it could be routed before and after the Amp? I have some questions that I will list below.
The reason for this trouble: I'm looking to experiment with wet-dry configurations and different FX both analog and from the HX stomp.
Signal path: This is the layout in my mind but haven't been able to reproduce in real life completely d/t lack of all cables, space, etc.
Guitar > cali 76 comp > In
Loop 1: EHX soul food
Loop 2: Double Dreamer
Loop 3: Strymon Riverside
Loop 4 (split): Phase 90
Loop 5: Out only, no return to HX stomp stereo input
Loop 6: Out only, no return to Empress echosystem stereo input
Insert Loop (mono): Effects loop of HX stomp
Loop 7: BB preamp
Out > amp > captor X > mixing console
The main stereo output from the HX stomp and the echosystem > Rolls line mixer > GFI cabzeus stereo > mixing console.
Questions:
- I want to have the FX from the HX stomp going into the Amp through the FX loop of the HX stomp to keep the time-based effects and some modulation through the main outputs to my "wet" system. How can I route this? Am I wiring this correctly from the layout above?
- Should I instead put the amp as a separate loop? Is there an advantage to it?
- Can I split the loops 5 and 6 to add more/other pedals?
- (not necessarily related to PBC) Could I be using the HX stomp cab simulator to replace the cabzeus?
