7 Stringer
Hi there,
I have a G System and an RG16.
I have the send of loop 6 of the RG16 connected to my return loop of my amp so i can use it as a mute for tuning. My tuner out is plugged in the Pitch Black Pro tuner.
i have setup my G system boost switch to change loop 6 (CC 85) on and off. But my problem is that the loop 6 is always off when i change patches, i need to hit the boost to activate it (Have sound). I need the reverse effect, the loop needs to be on all the time as when i hit the boost, it turns it off so i can tune silently.
I know CC messages from 0-63 turns a loop off and 64-127 turns it on but how do i go about changing that?
What do i need to do to have the loop 6 always on and then off when i hit the boost button?
I hope i explained my problem correctly here, not used to MIDI that much.
Thanks
Chris
Thanks
Chris
