GuitarGirlTS9
I'm trying to set up have one of the buttons on the GT16 to activate the Stack/Hold function in the FM3's Delay and Reverb blocks. I thought it would be simple and I would just choose External 2 as the source in FM3Edit for the Stack/Hold and then in MMGTEditor have the button do a CC Toggle action for the FM3 Ext Ctrl2, but nope. It doesn't activate it at all with the Stack/Hold staying off.
The reason I want to use External 2 is because I have External 1 set to an expression pedal, which works with no problems. I can even get the Stack/hold to work if I set it to Ext Ctrl1 for the FM3, but I want to activate the Stack/Hold with a button on the GT16 and not an expressional pedal nor an external TRS switch on the GT16 or FM3.
I've been wasting an hour trying to figure this out and I'm sure that the solution will take seconds to make it happen.
