Chuk
I'm a little confused about the 'Preset Button 2nd Press' function.
I have it set to 'RELOAD' but it behaves unexpectedly.
For instance; when I load a Preset then select any IA (Drive1 for example) but then re-select the Preset it does not revert to the saved state as I would expect ie it doesn't reload. It remains with Drive 1 engaged. However if I load a Preset then select another Scene other than Scene 1 then re-select the Preset it DOES revert to it's saved state. In fact every other Scene other than Scene 1 will revert to the default/saved state upon re-loading the Preset. Strangely, Scene 1 WILL reload it's default state if I select the Scene 1 IA button but not the Preset button.
It seems to be a problem with the Scene button, regardless of which one, that is saved with the preset.
Hopefully that's not too confusing.
Does anyone have any insight into what could be causing this behaviour?
