is9582
GT22 FW-4.9.0 AF3 - FW-20.02
I’m using an Ernie Ball Jr. expression pedal, that I re-wired over a year ago, correcting the polarity so it will work with the GT22. It has been working correctly since the re-wiring, and has been connected for this whole time, until I noticed it last night. I unplugged and replugged the cable into both the expression pedal and the GT22 port, to make sure no corrosion was at play. I’ve not been playing out, and always practicing by myself, so I keep the expression pedal set to full on, and it sets beside my GT22.
When I noticed it wasn’t working, I tried going back through the setup process. My AF3 just doesn’t recognize it, even with the proper CC#11 set for Ext #1. I’ve not noticed anything else malfunctioning between the GT22 and AF3. I tested the cable, and between ring and sleeve there was 10.77 ohms and .99 ohms at the two end points. I also calibrated this pedal while connected to my GT22, and it recognized the pedal and was very nearly full range (2 to 127).
I’ve rebooted both the AF3 and GT22 (at the same time) yet can’t quite figure this one out. I’m sure I’m probably having another dang brain fart, but I’d appreciate input to get me going again.
Oh, all three front end setup between the AF3 and GT22 are still set as described in the manual.
Thanks in advance,
Lee
Thanks in advance,
Lee
