I recently set up my rack rig earlier today but I ran into a little problem. I'm trying to power my Voodoo Lab GCP via phantom power but I'm having a little trouble getting the GCP to start up. My signal path looks like this currently.
Guitar -> RG 16 -> OD pedals -> Front of amp -> Effects loop send to Eventide Timefactor -> TC Hall of Fame Reverb -> Return to amp via effects loop
I'm using a 5 pin midi cable connecting from the midi in jack on the timefactor into the midi thru jack on the RG 16, and I'm using a 5 to 7 pin midi cable for the GCP. 7 pin side on the midi in jack of the RG 16, and 5 pin side on the midi out jack on the GCP. I'm powering all of this with a Furman PL8C Power Conditioner.
Did I use a wrong midi cable? Is the midi cable from the RG 16 to GCP supposed to be a 7 pin midi cable on both sides? If not, what is the problem?
Thanks.
Thanks.
