EVHGuy1111
1. Will they be produced again, they are currently discontinued and none are on the used secondary market.
2. What is the best way to route the MLM (or any line mixer) with a slaved Wet/Dry system?
My system currently is a mono system but I will be updrading it to a Wet/Dry system:
Guitar >
MEGX (Split mono effects with a split loop running into the Effects Loop of the slaved amp)
EVH 515OIII 5Ow (Master) will have effects in the front of the amp from the MEGX)
EVH 515OIII 5Ow (Slave) will have wet effects from the MEGX in the Effects Loop Return)
MMLT Foot Switcher (for controlling rig)
For this type of a rig, where would I put a line mixer to allow for natural decay when switching between presets/pedal-combinations/etc.?
The rig has to be slaved because slaving EVH amps allows for precise Tone/EQ control and manual volume control (this way I won't have to match the Tones/EQ and can just mix the presence of the Wet and Dry amps with volume controls).
What would be the way I need to go about routing to allow for trails?
Guitar >
