Hello,
I am still getting a handle on programming the Mastermind LT. Coming from the old Mastermind, several things are different about programming the LT. In the first video on programming the LT, after setting up button pages, you go to button pages, activate the what you want on the device, and then save using the Page/IA Store button. The video demonstrates that you can even recall program changes on devices, such as the H9, Mobius, and Timeline (all of which are in my rack). In other words, I don't have to program the MEG, for example, by first sending a program change message to the MEG, and then pressing the Write button on the MEG.
If I am understanding everything correctly, this new method of programming a preset works because on a device's setup page, you select "Send CCs on preset change" (and you have "Send On Preset Change" and "Update State On Preset Change" in each IA button.
Using this method of programming, I am having problems with programming a preset with my Y-Not and JP-2C. On the Y-Not Device page, I have everything setup as I described above and program the Y-Not in a preset as described above. However, when I choose the programmed preset, the Y-Not flashes the proper A or B selection, then goes dark and selects nothing. The same thing happens with the JP-2C. It seems as if each piece is receiving multiple messages, PC and CC. The only way to get these pieces to work is to turn off "Send On Preset Change" and program the old way, send a PC change, select what I want on the device, then press the write button (store switch on the JP-2C). I have tried turning off send PC changes and other things, but I cannot get these two pieces to work like the H9, Mobius, and Timeline.
Any idea what I am doing wrong? Thanks.
