[SOLVED] Amp Switching ... something "off" with Func switch?
kingb
Hi
My amp uses a mono cable to switch channels.
I've tried a couple of different cables (mono, trs > trs, trs > split)... the odd thing is that for both Func switch outputs, I can only switch my amp if BOTH switches are "on". From looking at the manual I would guess that either "1" or "3" should be on (tip) to make this work (not BOTH "1 + 2" or "3 + 4").
Is there a setting in the editior to adjust this? Or perhaps is my unit wired incorrectly?
-kb
Re: Amp Switching ... something "off" with Func switch?
Which amp is it? And, does it have a 1 or 2-button footswitch. My best guess is that the amp uses inverted switching (switch off = amp function on). If that's the case, you can invert the function switches in the PBC settings to fix it.
kingb
The amp is a Friedman Smallbox - one button footswitch (mono cable).
Inverting the second switch - allowed the first to work normally. Took me a few moments to realize that access to this is on the unit's global setup - couldn't find this in the editor.
All better now - Thanks!
Re: [SOLVED] Amp Switching ... something "off" with Func swi
Oops - looks like I missed those parameters in the editor! Will add them in the next release.
