sergicalhands
Anyone own one? Spring loaded model maybe? Im curious about the advantages or disadvantages of having it spring loaded. Do you lose anything?
Thanks
Thanks
I have one and decided not to get the spring loaded .
If you want it , for exemple, to control de speed of your delay, or a filter etc...
each time you lift your foot from the pedal, it will go the max/min value if you get the spring loaded.
Without the spring you can set the pedal mid point and it'll stay there when you lift your foot .
My 2 cents ....
I don't see any reason why you would ...Do you know if you'd lose the toe switch by going with the spring loaded version?
The toe switch is still there in the spring loaded version.
That would be a question for mission engineering who designs the pedalOne last question, given that the spring loaded has the auto engage, can do normal one do an "auto engage" like feature with out it being spring loaded?
