Lars Bøgh
Hi Ron
I have a question for the diagram in the Effect Gizmo manual page 19. To be specific the "send" cable, from both amps, going into EG In11. How should this cable be wired? - If you are using a standard insert cable, the one amps "send signal" will hit the tip of the TRS plug going into EG (left), while the other amps "send signal" would hit the ring of the TRS (right). I plan to use 5 stereo pedals: Eventide H9 --> Strymon Mobius --> TC Mimiq --> Strymon Timeline --> Strymon Big Sky, ending up with sending the left/right signal from EG.Out12 to the 2 amps return. I wonder if the first stereo pedal in this chain should receive only the left channel. If yes, this means the cable in question should be wired so both amps send, should hit the tip of the TRS? - Am I wrong?
