I will try to make this as short and sweet as possible and hopefully someone will have the answer. I'm sure it's probably user error. Ha.
My set up is as follows:
I have a Voodoo Lab Ground Control Pro running into an RG-16. I have the GCP set up in 4 preset mode. I am running a Line 6 M5 via MIDI in instant access switch 5. It runs all of my delays. It runs thru a Mini-Line Mixer thru my Bogner XTC fx loop so the delays can trail.
As an example, in one of my banks I have:
Preset 1 - Clean channel w/ delay
Preset 2 - Rhythm 1 channel w/ delay
Preset 3 - Rhythm 2 channel w/o delay
Preset 4 - Solo channel w/o delay
Here is the issue: When I'm using Preset 1 or 2 and switch to any other Preset the delay trails off correctly. When I'm in Preset 3 sometimes I like to turn my delay on but when I hit Preset 3 again to shut it off or change to any other Preset the delays DO NOT trail. Same with Preset 4. Actually any bank or any preset it's the same thing. If the delay is part of the actual Preset the delay will trail if I add it by stepping on the instant access switch then the delays do not trail. I'm completely baffled by this. I am going to post this here and at the Voodoo Lab forum and see if anyone knows what I'm doing wrong.
