shoelesscraig
I know nothing about this pedal, but it appears that maybe it can be ran in "dual" or "normal" mode. Which are you running? (Or am I completely wrong and there is no such thing?)
I'm not at the computer with the software installed, seeing your description...aside from what @shoelesscraig mentioned, you're trying to send two consecutive CC's to the same pedal which may be a problem. I'll look at in about an hour at the file...in the meantime, isn't CC 27 bypass? That's what you're wanting to do right?
Did you try my file? Curious as to what it did...
OK, I can see files Using Shoes file, can you go to page 4 on the pbc and see if you can control the pedal? Looks like Shoe created a group with only allowing 1 button on at a time...does this control the pedal?
Nothing as far as being able to control from the editor. Pressing the PBC presets 1 thru 3 Effect A stays on, when I get to preset 5 it switches to Effect B.
I previously hadn't gotten to my DD500 or Rv500, since they are in loops and no need to turn on or off via midi. That said I just tried and I am still able to turn both effects of the DD500 on and off no problem from the editor using a CC command. But it appears that the RV500 behaves the same as the MD500. Not sure why they did that. Frustrating.
