here is
When you make a change on the Axe III directly while Axe Edit is open, you’ll find that Axe Edit lags for a moment, then refreshes itself and adjusts to convey what the Axe III edits were, because the devices are constantly syncing with each other. There is usually a gap in sound during this readjustment of Axe Edit.
When you make a change to your Axe Fx via the GT, Axe Edit recognizes that as a change in the Axe Fx and Axe Edit begins the readjustment process, causing the delay and sound.
Hope this helps.
You have MIDI Receive Channel set at channel 1.
At this stage it's better to set it to None, I think, because I've noticed that it causes issues.
thanks, but this is not the point
-Until now the GT16, programmed manually (no bidirectional), worked perfectly on Axe III with Axe Edit III (no lag, no refresh, it was instantaneous)
-the problem is that now to engage a stomp I have to press the switch maybe 7-8 or 10 times, before it engage, and same thing if I have to switch off.
-when I change preset you can ear the gap audio two times, not one!
next week I start rehearsals for a musical, and this is a huge problem, because while I play I'll need Axe Edit open to make some adjustments on the fly, which does not make it possible to switch the stomps correctly.
Regarding the latest Axe-Edit III beta: no issues here.
It's not Axe-Edit, its something in your MIDI setup.
You're using non-default MIDI settings on your GT. Not only "MIDI Receive Channel", but you've also unchecked "Ignore Incoming PCs" in the GT. Do you also have "Send PC" enabled in the III's MIDI/Remote menu? That may cause issues.
As I wrote before: better to start with a factory reset.
BTW, the new GT firmware is very beta and there are bugs. RJM hasn't claimed that it is anywhere production-ready.
On the III set Ignore Redundant PC to ON.
On the GT set Ignore Incoming PC to ON.
Thanks for pointing that out, that one was easy to find and fix. Regarding the PPA, we will send you another one today.
I use my iPad connected with USB on GT16, for changing PC. When testing, suddenly the GT16 goes blank with only the IA Mode screen lit, and unable to use it. I have to reboot the GT to make it work again. I've always used it this way without problem with my Axe-FX II, really scared to use it at the tomorrow gig... I know it's a beta, just pointing the bug.
Anyone ???Hi everyone. I have All My Effects Buttons Set so that when I Press and hold them I get the Pop-Up of the Channel Select Menu. This is On The Main Page. It works great.
When I Go into the IA Page if I Hold one of the same Effect Buttons I don’t get the Pop-Up Menu... it just Cycles through the Channels.
Is this a Bug ?
My scenes on the GT16 don't sync with what is stored in the Axe-FX III, is it not possible ATM? Effect blocks sync well. I've tried with send on preset change checked or not, no luck.
