There's also a 3.0 editor!Only for the firmware the 3.0?
FYI, there is one known issue - on PCs with very high resolution displays, the PC editing boxes on the Presets tab of the editor look a little weird. I'm working on it and will get it fixed.
Check all of your buttons that cause the PBC to switch pages. The buttons should be set with Send on Preset Change and Update on Preset Change turned OFF and Momentary turned ON. That will prevent those buttons from triggering when switching presets.
Ron,
Had to go back to the beta last night. There's something in the release that's causing the BigSky decay times to randomly go to maximum. Changing the preset corrects it, and it may or may not happen again... It happened three times last night over the course of about 2 hours with no apparent cause, and I couldn't recreate it.
I just thought.......is it possible to assign two function to a button preset?
Ex: I press the preset button the first time and i turn ON my Bogner blue pedal by a Function Switch and the loop that i need, then i press a second time and I turn off the Bogner, the loop previously activated, and activate the loop where is the chorus. Is it possible?
I am considering that - it's difficult because there's not a lot of room on the screen, but I will probably find a place where it fits and makes sense.Hey Ron, and what do you think if the BPM information stays on the screen all the time? could be in a small size on a corner maybe, just in case you need to check the song BPM during a song, hope it helps to improve the firmware updates... thanks..
Are you using the expression pedal or IA button to control the BigSky decay times?
I am using the expression pedal to control decay times on the BigSky. It's still doing it in the beta, but not as often... has only happened once with the beta.
When it does this, what position is the expression pedal in? (Or does it matter?) Is the expression pedal set to go to maximum decay time at one end of its travel?
Ok, you're right, Update on Preset Change needs to be on for sure. Also, it looks like the flash w/ tempo setting is interfering with the sending of taps. I'll look into it.
