Firmware and editor 4.9.0 are now available! (Now updated to 4.9.1, see below...)
FEATURES:
-OR-
Firmware: https://www.rjmmusic.com/downloads/PBC/MM491.zip
Mac Editor: https://www.rjmmusic.com/downloads/PBC/MastermindEditor-4.9.1.dmg
PC Editor: https://www.rjmmusic.com/downloads/PBC/MastermindEditor-4.9.1.zip
PBC/6X Manual: https://www.rjmmusic.com/downloads/PBC6X/PBC6X Manual-4.3.pdf
PBC/10 Manual: https://www.rjmmusic.com/downloads/PBC/PBC Manual-4.2.pdf
FEATURES:
- New device support:
- Red Panda Bitmap 2 and Raster 2
- Strymon V2 pedals: Bluesky, Deco, Dig, El Capistan, Flint, Lex
- Wampler Metaverse
- Fixed the Off Preset LED color option, which didn't quite work in 4.8.1
- Added Dynamic Distortion block support in Axe-Fx III
- Fixed an editor bug in the PC messages section that can cause PCs to be sent when they aren't supposed to
- A proposed fix to a problem that caused the editor to hang during settings transfers on Macs. Let's hope this works!
- Fixed the inability to select a few Axe-Fx III CCs at the end of the CC list
- Fix bug that prevented Song action from updating preset button names
-OR-
