Chris Green
Both the M1 MacBook and the iMac did. I’m wondering if I should go back to 4.8.1. How do I tell if my PBC was built after March 2019?
That did the trick, thank you!Looks like preset 1's loop order got corrupted somehow. Copy preset 2 to preset 1, then you should be able to edit preset 1 normally.
If it's only connected to the MIDI out and not the MIDI In, it can't affect anything at all. The MIDI In shouldn't affect anything, but unplugging anything that might be plugged in there that is worth trying.No other MIDI Devices connected to the Mac externally. I have Ableton Live Suite 11 installed, but shut down when updating the PBC. I haven’t used that with the PBC yet, although I plan to.
I use a transcription program called Transcibe! that I connect the PBC to and control via midi using the same USB cable. I have a button page setup for that. It’s usually shut down when I update the PBC.
I have a Strymon Timeline and Mobius connected to the PBC with midi. It’s never been a problem before. Should I try unplugging the midi out of the PBC before an update?
No, just use the normal Save or Save As functions.Hi Ron. I tried uploading the export of everything read from the PBC last night. I couldn’t get it to save with my post. Is it the export from the file menu of the Editor?
Hey Ron! I wanted to chime in and say I'm having this exact same problem and I don't know how to fix it either. I updated my RJM and Editor to the latest 4.9.0 firmware last week and since then I have this same issue down to the T just as Chris does.Hi Ron. Thanks for constantly updating and improving. I've updated the Mastermind PBC 10 and editor to 4.9.0. Every time I make a change in the editor, I get the spinning beach ball after writing changes to device. It doesn't come back and I have to force quit and relaunch every time. I'm on MacOS Monterey 12.4 on an M1 MacBook Pro.
Is this happening to anyone else?
You should be able to upload the file here, but since that's not working, please send to support@rjmmusic.com instead.Not sure what I'm doing wrong, but I've tried to upload my settings several times unsuccessfully. It gets to 100% and seems fine until I save the post and the settings aren't included. On my Mac I use Safari. I also emailed the settings to my work PC and tried to upload them here with Google Chrome. Also unsuccessful. Can the .rjs file normally be uploaded to a forum post?
email sent. ThanksYou should be able to upload the file here, but since that's not working, please send to support@rjmmusic.com instead.
If you guys figure out a solution let me know as I'm having this exact issue just as Chris Green.You should be able to upload the file here, but since that's not working, please send to support@rjmmusic.com instead.
