zatch_attach
Hey guys!
I'm redoing my Mastermind PBC-based board and am seeking the easiest solution to integrate an always-on tuner. I have a Sonic Research ST-300 mini that fits my accuracy and size needs, but mutes the signal when it's in the path (the normal-sized ST-300 has a tuner monitor option, the mini does not).
I'm maxed out on power outlets and would like to avoid splitting my signal with another buffer if possible.
I came across this post stating that the insert loop could be used as a tuner out if the tuner is only connected to the send:
www.rjmmusic.com
However, when I connected a standard mono TS cable to my "Out 1-4" jack and my tuner input, it mutes my signal, where I expected based on the above post that without anything plugged into "In 5-6" that the PBC would split my signal at the insert send and pass it through to the next loops.
Anyone have any experience I can benefit from? Do I need a special cable?
Thanks in advance!
Is there a good way to keep a tuner 'on' but out of the signal?
I have a Boss TU2 that I'd like to have 'on' at all times, but out of the signal (ie. like using a 'tuner out' of a volume pedal). Is there an easy way to do this, or will it require splitting the dry signal up front before going into the MM PBC? I suppose I could use one of the insert points...
Thanks in advance!
