Budro Thedog
Ron,
*****************update 3:20pm****************
I was able to create a workaround for the issue below. I added a new generic midi device to my mmgt setup, and assigned it the same midi channel as the axe. I then created an IA switch, assiged it to the generic midi device, and seutp a midi cc to an open slot for scene increment. (cc togle #112 off:None on:127). I then assigned that midi cc on the axe.
Works like a charm.
Would still appreciate some comments on my original post though.
*****************Original post*******************
I have an IA switch setup to increment scenes, but, it does not appear to be working. On the MMGT, I have
"CC Togle #123 off:None on:127", and, on my AXE III i setup scene increment to be midi CC 123.
Would this seutp work in the latest release?
Running 4.1 B2 on the MMGT22 and 1.14 on the AXE.
Also, do we need to setup the AXE to a specific list of MIDI CCs for the different blocks?
When I first received my AXE III, I setup the MIDI CC's on the AXE to match the AXE MKII+. However, that dpes not appear to work anymore.
For example, I have an IA setup on my MMGT to disable all amps and cabs on the axe3. I was using midi CC 38-40, and had those setup on the AXE as well. Now when I press that IA, the inputs on the axe turn on & off.
Or is all of this moot given that you have created the device specific integration? In other words, if I am using AXE mode on the mmgt, do I even need to configure any MIDI CCs on the axe? Or, is that only if i'm using generic midi controller mode?
Works like a charm.
