Hi,
Finally have the time to test out the beta, and convert my settings. However, I'm having an issue with 'get preset names', because of the way I have my gear set up. Some info about my midi chain:
I've put a midi merge box after the Axe FX, to merge the midi out and midi through ports. This way I can send midi commands from the Axe FX and my GT to the other midi devices in my rack. For example: all PC's for my H9 are stored in the Axe FX, but I can still use the GT expression pedal, because the midi is merged before it gets to the H9.
The merge box has two outputs, one of which goes to the rest of the rack, the other one goes back to the GT.
In this setup the tuner for instance works fine on the GT. Getting preset names however doesn't work, the names get all scrambled. I've found a workaround by disconnecting the through cable from the axe fx when I'm getting the names. Then it works just fine. Could there be a solution so I don't have to open up the back of my rack every time I want to get preset names? Or does the merging create issues that cannot be solved?
